Unplugging Radiator Fan Relay Switch
Old May 26, 2010 | 11:05 AM
rehfg8's Avatar
Default Unplugging Radiator Fan Relay Switch
After finding the radiator relay switch under the battery in 2001 Jetta, i cannot get the plug off of the switch. There's a little tooth that the plug clips over but no way of unclipping it. Anyone have any help/ideas/tips for getting this plug off the switch?
Old Jun 9, 2010 | 04:55 PM
afarfalla's Avatar
go to harbor freight and purchase their pick set, usually 4 in a pack, bright colored green or orange, one pick is 90 degrees, at the base of the connector on the clip side, gently work the tip of the pick up the connector this should release the connector keep, then pull, the connector should come off the module
Odins Les Paul
Feb 9, 2010 08:21 PM
erics_beetle
Dec 18, 2009 02:30 PM
Ddort1
Jul 13, 2009 02:28 PM
msholmes
Jul 9, 2008 08:36 PM
jakejetta
Sep 1, 2007 03:20 AM
