Uneven wear on rear tires.
Hey was up? I own a 04.5 GLI, and I'm getting diagonal flatspots on the rear tires. I've been to the dealer and had it checked, but nothing was wrong. The wierd thing bout it is, this is the second set of tires, and it didnt happen to the first set. I was wondering if anyone knew of anything it could be?
RE: Uneven wear on rear tires.
possibly the tierods? or bad boots? not sure.. my tires were wearing and i had to get new tierods along with an allignment.
could be something wrong with the tires, but it sounds to me like it is the shocks
Nothing unusual about scolloped rear tires on front wheel
drive vehicles of any type. If your lucky and have the correct tire tread they may not scollop out, by the way that tire wear pattern were talking about is called Heal and Toe wear by tire dealers. To stop it you have to keep the correct tire pressure at all times and rotate the tires often. High speed driving will also cause the same wear pattern to appear. The tire tread design with a ugly straight look will not usually give heal and toe wear, but when you go to the agressive look they will do it. NO IT'S NOT BROKEN, AND NO TIE RODS BAD. |
| All times are GMT -5. The time now is 10:13 AM. |
