-   -   Turning Off Low Tire Pressure Light on 2017 Jetta (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/turning-off-low-tire-pressure-light-2017-jetta-37409/)
whitey ford Jul 27, 2017 07:10 PM
Turn ignition on, without starting, and push the (!) button inside the glovebox, top left, and hold until audible tone. DONE!
Start vehicle and check your work.
Keithuk Jul 28, 2017 06:28 AM
You only press the SET button in the glovebox when you have changed the tyre pressures so the ABS sensors (if you have an indirect TPMS system) can recalibrate. Direct TPMS uses pressure sensors in each wheel.
You need to find someone with VAG-COM\VCDS to do a full AutoScan and check the system out, post any error codes found?
whitey ford Jul 29, 2017 01:39 PM
I respectfully disagree! Got tires rotated and they filled to 32 psi instead of 36 psi as specified by drives door label. Got the (!) on the way back. Filled tires up to specification and reset the light.
Just trying to help others who may just need to reset low tire indicator (!) light after a low tire pressure occurrence.
Very quick takes 8 seconds!
Keithuk Jul 30, 2017 07:10 AM
Why do you disagree with what I said its the same as what you say?
