Turn signal and brke ligth problems on 1996 Volkwagen Jetta
Old Nov 19, 2006 | 01:08 AM
Jetta57's Avatar
Default Turn signal and brke ligth problems on 1996 Volkwagen Jetta
My daughter has a 1996 Jetta and just recently it developed a problem with the turn signals. Regardless which direction you switch the turn signal indicator both sides flash in the rear as if the emergency flashers are on. When you apply the brake with the turn signal on they stop flashing. Does anyone have any ideas?????
Old May 9, 2007 | 02:19 PM
christer's Avatar
Default RE: Turn signal and brke ligth problems on 1996 Volkwagen Jetta
no, but if you find out what's wrong let me know... I'm having the same issue
Old May 18, 2007 | 04:49 AM
shoughun's Avatar
When a friend of had the same problem with his Jeep turn signal, we assumed that it was a faulty wiring causing it not to function properly... But when brought it to the mechanic, he replaced the switch and it was fixed instantly... Hope this helps... But it does not work, try also to check the fuses... Goodluck!!!
Old May 18, 2007 | 11:39 AM
Timmyboy's Avatar
there should be a brake harness under the sterring column or around there somewhere. this harness controls your turn signals and your brake lights. the harness might be bad. you can pick one up at the auto parts store for pretty cheap
Hope this helps!!
Market11
Aug 19, 2011 02:38 AM
Z40sx
Jul 28, 2007 05:04 PM
rafacl
Apr 25, 2007 02:44 PM
nocturnal
Jan 26, 2006 12:56 AM
Z40sx
Jan 23, 2006 12:24 AM
