Transmission Swap
Will a transmission from a 96 passat vr6 with the 2.8L engine work with a 99 jetta vr6 with the 2.8l engine?
Yeah, it should work. Do you have the mk3 or mk4??
what does that mean? I just know its an automatic transmission
The passat is a 96 glx vr6
ok the passat is an MK4
I mean, do you still have the old style jetta or the newer...?? In the middle of 99 VW started making the new jetta's.
It should work out because it was the same transmission that they used for the Jettas.. |
The Jetta looks like the older style
How hard is it to remove and install the Jetta Tranny?
If you have some experience and the equipment. Then, it shouldnt be that hard. Here are the instructions... Transmission, removing/installing
Removing
Proceed in reverse order of removal and note the following:
THanks for the info elroco. I have tried removing the motor and transmission mount. Well, was not that easy for me though. But I have searched for guides and DIY's for it.
| All times are GMT -5. The time now is 07:58 AM. |
