-   -   timing chain or belt? (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/timing-chain-belt-6638/)
dbaseballs Oct 13, 2008 11:48 PM
I have an 03 vw jetta gli with the 24v vr6 does it have a timing chain or a timing belt?
dbaseballs Oct 14, 2008 10:32 AM
RE: timing chain or belt?
well the reason i ask is cause my auto teacher said it was a chain my mechanic said it was a belt, and if you looking in the oil fill opening you can see a chain right there
Jrailer Oct 14, 2008 02:23 PM
vr6 is chain it runs on the inner end of the motor between the engine and trans
you need to pull the trans out to do a full timing chain job
gscgabe08 Oct 20, 2008 04:36 PM
so i herd that if u have a timing chain that u shudnt worry about it as much as the belt & that it outlasts the motor. is that true? if not, how often shud u change the chain? (00 jetta glx vr6)
Jrailer Oct 20, 2008 10:10 PM
true you can get allot of life out of a chain and you can here them as they get worn
