sun/moon roof
I'm new to this forum. I have been searching the net high and low for a solution to my 1999 jetta's leaking sun roof.I have fixed the problem with the plugged up drain lines and the water leaking in the drivers compartment has appeared to stop. The underlying problem with the leaking sun roof is that water is getting by the seal .I assume the drain tubes are there in case you get a leak?? I can hear air leaking in while I drive. I can not find any where if the sun roof can be adjusted..or how to replace the seal .does anyone have any info on either of these problems? Thanks in advance for any help.....Tonebone
