-   -   Steering wheel knock (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/steering-wheel-knock-449/)
jsun Jan 16, 2006 06:20 PM
I just had my
inner tie rod replaced,
rear wheel bearings replaced,
2 new tires
and front end alignment
but my steering wheel still makes a knocking feel. especially if i'm sitting still and move it side to side. and if i'm slowing down i can feel it in the steering wheel and brake pedal at the same time. It runs a lot smoother than befor but it still does that. It's a '98 Jetta. Anyone have any ideas of what it could be.
Jsd Jan 17, 2006 10:09 PM
RE: Steering wheel knock
Are you sure something isn't hitting the steering assembly? Might wann have another shop take a look at it, or just check yourself, that's my best advice.
-Jeff
shmoody Jan 26, 2006 12:50 AM
Lube you intermediate shaft.... the one that comes from the steering column down to a u-joint into the another shaft into a ujoint and then into the intermediate shaft...
Just a try,
It fixes your problem on toyota all day long at work....
also use a generous amount of grease (TONS) rock it side to side when your all good n tite... it should go away, if it is the same thing...
Carfull or your wheel will be off-centered...
