squeaky tensioner/serpentine belt
i looked it up and apparently the problem is the pulley?
how can i fix this myself? i am a decent mechanic as long as i know what to do lol. |
RE: squeaky tensioner/serpentine belt
What year is your car and what engine do you have?
2000 2.0
the gls |
pull the belt off and pull the three 13mm bolts holding the tens and pully and replace
15 min job use a 16 mm wrench to loosen the belt on the tens. |
sounds quick, is there anything tricky to it at all? like location of the 3 bolts? Or will i have to lift the car for anything? If not sounds like i can knock this out pretty quick.
| All times are GMT -5. The time now is 06:13 AM. |
