Speed Sensor Location on 01 Jetta auto
Hi, I'm trying to replace the speed sensor on my cousin's 2001 Jetta. It has an automatic transmition. Can anyone tell me where speed sensor is located. We got the part but I can't figure out where it is on the transmitiion. His speedometer isn't working at high speeds and the cruise control stopped working at those speeds so I think it's the sensor. Thanks!!
Well, there is an RPM speed sensor attached to the front side of the block. The other one should on top of your transmission. Mine is a 98 Jetta, so it has two on top of transmission.
Let me me know if you find it... |
Hi, what I'm looking for is the sensor on the transmission that sends the data to the speedometer for speed. I've looked everywhere I can see on the transmission and the only sensor I could find was the crank positioning sensor. I'm assuming it's under something where I can't see it but it's not in the Hayes maintenance manual so I'm in desperate need of help. Thanks,
Yeah, i know what you mean. Like on my Jetta, since is a 98. That sensor is on top of the differential, on the back of the transmission. Do you have a 4speed transmission? and is it a 2.0L?
G22 - Speedometer Vehicle Speed Sensor (VSS) (Automatic transmission)
http://alldatapro.com/alldata/PRO~V1...9838/115289839 http://alldatapro.com/alldata/PRO~V1...9838/115289840
It's a 2.0L engine code B. Does that change anything about the infomation above on it's location? Thanks!!
No, it doesnt change. Is the same engine and transmission. Did you find it?
I don't get to try again till this weekend, he lives a couple hours away from me. I'll let you all know how it turns out. Thanks!!!
Originally Posted by elrocco88
(Post 36668)
sorry, accidental double post
