Rear door panel - 99 Jetta
Anyone here know how I go about removing and replacing the rear door panel on a 99 Jetta? My electric window is frozen in the down position and I need to get in there and fix it.
Thanks |
Originally Posted by johnarensberg
(Post 55835)
Thanks There should be three torque head screws on the very bottom of the panel holding it down and possibly a screw or two on the front side of the door panel. Possibly a screw or two in the arm rest. After that you need to GENTLY pry the door panel away from the door frame with a flat blade screw driver and it should pop the little things that secure it in place out without too much force or trouble. Once you do that you will need to pull it out enough to see behind it and detach any of the wires. Then you can pull the panel up and it should unlatch from the window sill area. Presto the inner door panel is off, but there may also be a metal plate under it that you might have to take off to get at the window and the window motor.(there was on the front door, not sure about the rear YET) Do you have a new motor for the window in case that is the problem? |
| All times are GMT -5. The time now is 02:49 AM. |
