quick question someone with any advice please help
ok first off hi everyone this is my first post. k now i have a 1996 jetta 2.0 5 speed. tonight i took off the lower control arms off to press in the new bushings in the rear of the control arm and i now have two questions. does the bushing that is like a barrell on the front of the lower control arm press in and out? k now the next question is my biggest worry. with the control arms off i grab and push up on the strut and it moves up and there is like a 1/2 inch gap on the engine bay side of the tower between the tower and the rubber part and when i let go then the rubber sits flush on the tower. both sides are the same but to me it shouldnt do that. now my question is do i just take that nut off on the top and drop the strut down and its just a bottom bushing and a top bushing that sandwich the tower? im sure im not that lucky. i just hope the spring doesnt need to come off the strut. any advice will be much appreciated.
thanks jesse |
RE: quick question someone with any advice please help
the strut tops have some play in them the newer ones are allways loose i wouldnt be worried and you would need a spring compressor
the bushing on the controle arm can be pressed but its a real pain |
hey thank you very much for the reply jrailer. just looked kinda odd to me so i thought i would ask. do you happen to know how to program the key fobs to the car to lock and unlock the doors? i got the car a few months ago and there were like 4 fobs in the center console but none do anything. thanks again for your help.
thanks jesse |
if you have two keys you can
one in igntion turn key to run without starting then lock door with other key and press fob at the same time i think this works i will look it up tomarow (friday) |
