-   -   please help p0411 help (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/please-help-p0411-help-36563/)
ffarid109 Sep 3, 2014 09:00 PM
I have jetta 2.0 year 2000. the mileage 227000 miles, Gas engine. the code p0411 came up for the sec/air injection. the air injection works and I can hear it but whats next process for this code.
Keithuk Sep 4, 2014 07:10 AM
1 Attachment(s)
Welcome to the forum. Attachment 2574
VAG Error Code: 16795
EOBD II Error Code: P0411
Fault Location:
Secondary Air Injection (AIR) System - Incorrect Flow Detected - Intermittent
Possible Cause:
Wiring/Connector(s).
Fuel Pump Relay (J17) faulty.
Hoses/Pipes to/between Components faulty/clogged.
Secondary Air (AIR) Injection Pump (V101) faulty.
Secondary Air (AIR) Injection Pump Relay (J299) faulty.
Secondary Air (AIR) Injection Solenoid Valve (N112) faulty.
Possible Solutions:
Check Fuel Pump Relay (J17).
Check Hoses/Pipes to/between Components.
Check Secondary Air (AIR) Injection Hoses/Pipes for Carbonization.
Check Secondary Air (AIR) Injection Pump (V101).
Check Secondary Air (AIR) Injection Pump Relay (J299).
Check Secondary Air (AIR) Injection Solenoid Valve (N112).
When is the code detected?:
The secondary air injection system does not detect the presence of air in the exhaust when introduced by the secondary air injection system.
Description:
An air pump is used on the vehicle to lower tail pipe emissions on start-up. The Powertrain Control Module (PCM) grounds the Air pump relay control circuit which energizes the Air pump. The Powertrain Control Module (PCM) also grounds the Air combination valve vacuum control solenoid circuit, which energizes the Air vacuum control solenoid. Vacuum is then applied to both Air combination valve diaphragms which opens the shut off valves. The Powertrain Control Module (PCM) enables both circuits simultaneously when Air system operations id desired. When the AIR system is active, then Air pump forces fresh air into the exhaust stream in order to accelerate catalyst operation. The AIR combination valves replace the conventional check valves. When the AIR system is inactive the shut off valves prevent air flow in either direction.
ffarid109 Sep 7, 2014 01:47 PM
Hi Thank you so much Keith for your prompt and excellent diagnosis. God Bless you
the car is 2.0 L/ jetta MKIV, AEG, I dont know if that helps. but I been trying to up keep it as much as possible. thank you again
