Overheating 2002 vw Jetta
Old Sep 3, 2011 | 06:20 PM
Jettababy7's Avatar
Default Overheating 2002 vw Jetta
My 2002 jw Jetta, 2.0 is overheating.... Just starting happening today.. Had to pull over and shut it off after the light came on...& we already changed the thermostat.... Still overheating.... Any advice on what to do?? Thanks !
Old Sep 10, 2011 | 03:17 PM
09s5speed's Avatar
i dont know your mechanical abilities but start the car and let it run just long enough to get it noticeably warm on the upper radiator hose. fell both the upper hose and lower hose. if the tops a lot warmer than the bottom then id guess the water pumps not circulating the water through the engine. or you could also check the weap holes on the water pump for any signs of leaks.
beetlebug
Aug 17, 2008 06:35 PM
lpe629
May 17, 2008 05:03 PM
khakiVeeDUB
Sep 11, 2007 12:37 AM
seanpermck
May 23, 2007 06:14 AM
NAFAN21
Jul 31, 2006 10:51 PM
