jetta transmission
Old 07-31-2008, 11:46 PM
xzacattakx's Avatar
Default jetta transmission
i have a 1999.5mk4 jetta witha standard transmission and a2.0 ...i need a used transmission and i need to kno what all transmissions will work for this car and what the exact transmission is called cuz im gettin one from a junkyard but i need to kno what all ones will mount up...but if i can ill try to get one outta the same exact kind of vehicle but if i can fid a cheap one that will work ill get it so plz hlp...im bout broke and i need my car fixed so help me out guys
Old 08-01-2008, 08:13 AM
racerx002's Avatar
Default RE: jetta transmission
I would getone with the same code just to be safe. There are 13 different 02J transmissions that fit the 2.0. Some have different gear ratios too. You'll find the trans code stamped either near the gear selector or near the flywheel.
libertyh
04-27-2007 02:47 AM
gbest
08-31-2006 06:35 AM
MainStreet228
08-22-2006 08:18 PM
MainStreet228
08-19-2006 12:31 PM
oleg_8831
05-25-2006 07:10 PM
Quick Reply: jetta transmission
