O3 Jetta 1.8T Tranny Help!!!
here's the deal... bout 6 months back my jetta started slipping 2-3 shift... it acted like it was one big gear... the kicker is that you can feel 3rd go in but it keeps the same rpm band and once the tranny fluid heats up it shifts fine... i'm talking bout PERFECT!!! i replaced the tranny fluid and nothing changed... checked codes and i got 00300 tranny fluid temp sensor and 00652 gear monitoring implausible signal... i replaced 2 solenoids on the bottom right of the valve body because my friend told me that was the most common problem... it didn't help... now i'm out :mad: $477 and the car is the same lol... Need sum serious help on this one :D
