no low beam on right side
Old Jan 24, 2007 | 10:36 PM
user 69780823's Avatar
Banned
Default no low beam on right side
2000 Jetta VR6
My left low-beam does not work. I know it is not the bulb as it is new and I switched them and the problem remained on the left.
ideas as to the likely cause?
Oh, and I lost the lock to the light down below. Can you believe it? ARG!! are they easy to find and cheap?
Old Jan 24, 2007 | 10:50 PM
bagel's Avatar
Default RE: no low beam on right side
Switch the left and right bulbs, see what happens. If the problem is still there, then it's a wiring issue, possibly.
Old Jan 24, 2007 | 11:24 PM
Banned
that's what I said. I switched them and therefore know it is not the bulbs.
Even if someone knows whichcolor wire is responsible for low beam that could help.
Also, how the hell do you remove, not the light from the head light, but the other end? I can't for the life of me figure that out. I tried using my screw driver and snapped off that little plastic bit.
Finally, could it be as simple as a fuse? That doesn't make sense to me since
the problem was intermittent (and low-beam is fully off now)
it only applies to low-beam. Wouldn't a fuse apply to the entire left light?
(just wanted to add, I just swapped fuses and the problem remaind so it is not the fuse)
Old Jan 25, 2007 | 12:55 AM
bagel's Avatar
CHiltons or other repair manuals have wiring diagrams in them. Look and see if the wire is chaffed, or burnt, or anything wrong. That plastic piece does suck, I think you squeeze and turn, if it's what I think you have. Took me like 30 min just to figure that stupid thing out.
bunnyrabbit86
Nov 1, 2011 02:13 AM
Feb 6, 2011 09:20 AM
Jan 28, 2011 01:54 AM
user 69780823
Jan 13, 2007 09:42 PM
imprezu
Dec 5, 2006 06:08 PM
