No INTERIOR LIGHTS! HELP
I have a 2003 Jetta, the interior lights are not working. No dash board lights, no radio or climate control lights. Also the buttons on the doors are not working. I just put a new lighting control switch. The door lights and dome lights all work. I have checked all of the fuse.
Originally Posted by cshort
(Post 26606)
Did this happen right after you put in the new lighting control switch, or did you do that to try to fix the problem? I know that you said that you already checked all of the fuses, but check them again. It might not be the fuse that you think it is, if it is one that is on the same circuit it could cause multiple problems. Once I had my power door locks, interior lights, alarm, and radio all stop working from just the interior lights fuse. Recheck ALL of them. All I can think of is that it is a fuse. |
| All times are GMT -5. The time now is 02:08 AM. |
