New to the site having numerous problems
Old Sep 23, 2008 | 12:04 PM
aguaholic's Avatar
Default New to the site having numerous problems
Hello,
I have a 98 jetta 2.0. My trans just died and i got it replaced. rebuilt trans, new clutch, new speed sensor. My speedo on my cluster is not working at all. Also, my gas gauge acts up. When i shift from like 1st to 2nd the gas gauge drops and the gas light comes on then goes back to where it should. My ignition was on it's way out before the trans. The guy that did my trans must of beat the **** out of my ignition because when i went to pick the car up after the trans was done the ignition was dead...luckly i had one sitting around since i knew it was on it's way out. Replaced the ignition...thinking that could possibly be the reason why my cluster was acting up. Nope...car starts fine but i still have the same problem. Could he have fried something out while doing the trans?
I am having some electrical issues as well. The PO didn't really take good care of the car. So i am trying to get it back to where it should be.
Question #2 My trunk button stopped working...I believe it's on fuse position #22 along with the cig lighter and radio. I checked it and it was blown. I giggled the relay and fuse box under the kick panel. Now the truck pops open without a 10amp fuse in the slot.
Sorry for the long post....I just need to get these thing fixed.
Thanks in advance
Sheldon
Old Sep 23, 2008 | 06:51 PM
aguaholic's Avatar
Default RE: New to the site having numerous problems
bumpy bump...i need some answers..
Thanks
Old Sep 23, 2008 | 07:39 PM
Jrailer's Avatar
check the big ground wire that goes to one of your bell housing bolts might have left it loose
Old Sep 24, 2008 | 08:34 AM
aguaholic's Avatar
I will take a look at it today after work....Thanks
Old Sep 24, 2008 | 04:36 PM
MonKENy's Avatar
maybe talk to this guy? https://volkswagenforum.com/m_16641/tm.htm
Old Sep 24, 2008 | 06:08 PM
VdubMa's Avatar
Member
Well dude i cant help you with your probs...but it seems like you got a lemon of a jetta...and that always sucks
Prince Dark
Aug 8, 2011 03:34 AM
Natec22
May 1, 2009 05:03 AM
Loljr
Sep 2, 2008 07:14 PM
marcia
Nov 5, 2007 06:18 PM
