-   -   need help pls. (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/need-help-pls-4073/)
josef4334 Sep 20, 2007 12:30 PM
need help pls.
hello guys. im new here. i need help with my cooling system problem. i need to find where the fan control module on my 2001 jetta 1.8t.the cooling fan on my car is not turning on. thanks for the help in advance
Getta Trek Sep 29, 2007 02:50 AM
RE: need help pls.
Normally, if there is a problem with the control module, the fan will run continually. Turn the AC on. Fan should be running. Check for voltage at the fan quick disconnect. If no voltage, check your fuse. If there is 12 volts, then the fan motor is shot.
