need help pls.
Old Sep 20, 2007 | 12:30 PM
josef4334's Avatar
Default need help pls.
hello guys. im new here. i need help with my cooling system problem. i need to find where the fan control module on my 2001 jetta 1.8t.the cooling fan on my car is not turning on. thanks for the help in advance
Old Sep 29, 2007 | 02:50 AM
Getta Trek's Avatar
Default RE: need help pls.
Normally, if there is a problem with the control module, the fan will run continually. Turn the AC on. Fan should be running. Check for voltage at the fan quick disconnect. If no voltage, check your fuse. If there is 12 volts, then the fan motor is shot.
khakiVeeDUB
Sep 11, 2007 12:37 AM
speedup
May 7, 2007 01:32 PM
new golf boy
Apr 18, 2007 01:19 PM
pete_07
Jan 11, 2007 01:22 PM
steveo
Aug 17, 2006 04:44 PM
