-   -   Need Help/ Electrical problem !! (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/need-help-electrical-problem-1710/)
gsxr1100 Oct 26, 2006 09:57 AM
I have a 97-GLX Jetta VR-6. Problem is with the brake lights. The brake lights work fine during the day but, at night, when I turn the headlight switch to the "on" position, not only do the tail lights come on but, also the brake lights, and they stay on !! I believe there is a short in the circuit somewhere. Has anyone had this problem or have any ideas on how to resolve this matter? THANKS IN ADVANCE TO ALL THAT REPLY !!
bagel Oct 26, 2006 07:24 PM
RE: Need Help/ Electrical problem !!
Is there any caution lights on in the dash??
gsxr1100 Oct 27, 2006 08:25 AM
No, there are no warning lights of any kind. Thanks for your reply!
ndenn002 Dec 31, 2006 05:08 PM
check the relay maybe the relay is bad.
ndenn002 Jan 2, 2007 10:56 PM
also check all of your fuses and i'm pretty sure you've blown a few or a few are on the vurge..............
jonyjetta Jan 5, 2007 11:11 PM
DENN IS RIGHT ....CHECK FUSES ...THE BOX.....AND RELAYS.....BURNED CONTACT PINS ON THE BOX CREATE ALL KINDS OF PROBLEMS...SO DO LOOSE FUSES
CRMIE1 Feb 10, 2011 07:18 PM
Omg i got a 95 gl and same thing except i my turns stay solid with lights on.....cant figure it out changed turn signal switch and head light switch still not working ...if you find a solution please let me know................tks....
