Need help 03 jetta warms start problem
Okay, these are the problems that occur when I try to start my car. When I
start me car it won't start the battery light will go on. Not every time I try to start my car does it not start. The times that is doesn't start is usually when I have driven it and then it sits for a couple our. Sometimes if I drive from point A to point B and it is only a matter of minutes that the car is shut off it will not start. For example: if I do a whole bunch of errands with in a twenty minute time span every time I leave the place I was at it will not start. When I first discovered the problem I thought that the car would not ever be able to start again unless I fixed it immediately but that same time when it didn't start I decided to press the gas peddle as I was starting it and it will slowly go but it will shake and kind of make a putt, putt sound. Recently we discover that black smoke comes out of the exust pipe. The battery light is on when ever this happens as well. My engine light has been on solid for two to three months now. I have also noticed a sound when the car does decide to start up. It sounds like a squeaky air sound. almost like belt is loose. I also have noticed a squeaky sound when the I turn my steering wheel. I also noticed that when I pump on the gas and the car starts to run the car will idol for a long time some times at 20rrpm and sometimes 10rpm it will never drop back down to 0. Also when the car stays idled at 20rpm I turn my squeaky steering wheel and the idol speed will start to drop. Please help or give me some ideas this pretty sums up everything I have noticed about my car hopefully we can get to the bottom of it. |
RE: Need help 03 jetta warms start problem
As far as your engine light, you can download those codes and will tell you what the light is for. I'd have to look at it to tell you more than that, jsut get the engine codes, and it's a great start.
i know im a girlie newb
how can I get the codes for you? once I get them I will post it |
| All times are GMT -5. The time now is 06:12 AM. |
