my 95 jetta. HELP!
Old Feb 10, 2009 | 08:25 PM
shanorama's Avatar
Default my 95 jetta. HELP!
alright. great car, but i wish it was better. "1995 Jetta III GL"
first of all. theres a nasty click in reverse (transmission) Dont even want to think about how much that'll cost
there is oil leaking from every gasket. idk if its the pcv valve or what. cause there is oil leaking to my air filter
when in forward gears and taking turns it gets louder, there is a humming noise da da da da da really fast. kind of faint but still noticable.
the locks dont work on all doors when i set the alarm.
these things really bother me as its my first car. what can i do?
Old Feb 11, 2009 | 08:03 AM
racerx002's Avatar
Default RE: my 95 jetta. HELP!
Sounds like you need some new cv joints. Its easier and sometimes cheeper just to buy new axles. What engine do you have? And your door lock module might be bad.
Old Feb 11, 2009 | 07:26 PM
dabatman99's Avatar
The faint humming noise, does it get louder if you turn the wheel one way while driving down the road and kinda fade away if you turn the other way driving down the road? If so, it may be a front wheel bearing getting bad. I am replacing mine right now...not an easy job either...but of course whatever your problem is, it isn't anything money can't fix!
