jetta vr6 2001 power problem
Recently i had a big repair on the whole engine such as, new tension, guide valves, intake valves, 4 broken injectors, rebuilt headblock, headgasket, new chains and belt, new chain guides, oil pan, intake manifold, sensors, water pump, new coils, its wires and spark plugs. But i still feel like the car has no power at all, based on my friends vr6 which is same as mine. This car has 175k atm, i had to do this repair because it happen when my car was over heating and it was leaking (compression) from there i got f***ed with all those parts that were broken as mechanic said.
Any ideas why my car is not supost to push as it should? |
need help
Sounds like you may want to bring it back where you had it repaired. Good luck.
| All times are GMT -5. The time now is 10:30 AM. |
