Jetta 02' Knock Sensor/Check Engine Light
Old Apr 6, 2009 | 02:05 PM
daniellev86's Avatar
Default Jetta 02' Knock Sensor/Check Engine Light
My 2002 Jetta check engine light is on. I took it to a mechanic and the issue was a knock sensor code. Is this expensive to replace? Is this an easy fix? I need to get my check engine light off in order to pass New Hampshire state inspection. Please help!
Old Apr 7, 2009 | 11:37 AM
racerx002's Avatar
It's a pretty strait forward fix. 50 to 75 bucks if you do it yourself. Might be expensive if you take it to a mechanic.
Old Apr 7, 2009 | 05:18 PM
Could you direct me in how to change out the knock sensor? I would appreciate it.
Old Apr 8, 2009 | 03:20 PM
racerx002's Avatar
I can. What engine do you have?
Old Apr 8, 2009 | 05:41 PM
1.8Turbo
Old Apr 8, 2009 | 08:30 PM
racerx002's Avatar
They are both located right under the intake manifold to the left and right. Just disconnect the harness and remove the bolt. If you don't know which one it is you can take a multimeter and set it to continuity and if there isn't continuity the sensor is good if it does it's bad.
Tiko
Jul 9, 2010 01:32 PM
Tiko
Jul 8, 2010 01:30 AM
magea
Oct 8, 2007 10:55 PM
jeremiahlowell
Jun 20, 2007 09:22 PM
Lokey
Apr 26, 2006 02:55 PM
