Ignition won't turn
I have a 05 jetta that the ignition won't turn. I turns enough to unlock the steering wheel but won't turn the starter. Any thoughts? I have tried all the jiggling and key works on the doors.
1 Attachment(s)
Welcome to the forum Tom. Attachment 2623
Make sure you have enough power in the battery to the ignition switch, check connections. Then it sounds like you have a duff ignition switch. https://volkswagenforum.com/forum/ne...gnature-34185/ |
