I need help with a new exhaust on my 2000 jetta
Hi, i wanna replace my exhaust system with an aftermarket one so i can get a nice deeper sound from my 2.slow 2000 jetta.
I was wondering if i could just somehow do it for real cheap and easy with bolt ons? or do i have to do welding? And if i get a whole exhaust system, is it hard to install? Like im mostly worried about installation around the headers. Btw, links to guides or links to good deals would be appreciated. Thanks. |
RE: I need help with a new exhaust on my 2000 jetta
Theres no cheap way to replace your exhaust. If you want a deeper sound get a flow through muffler put on. It'll open up a couple of horses too.
True, just have an exhaust sop do it if you're so worried, a reputable shop wouldn't charge alot and screw you with shotty craftsmanship.
so far, nobody has helped...
i need rough estimates or something... and how long and how hard is it to do myself? |
olny welding will be connecting pipes and to the muffler. magnaflow is good cat-back system
also your exhaust is only as big as the smallest point so if your looking for sound get a cat back but if your looking for sound and hp do the whole thing.
well I don't have a turbo, so I think it made sense for me to do cat-back system, but I'm sure once I get a turbo I'm forced to do the whole downpipe, everything...right? Just thought I'd slide my own question in, hope ya don't mind...
so if i don't have a turbo? there is a cheaper method of getting the sound?
ORIGINAL: SwedishGP Bagel: Yes turbo back is the way to go, same size all the way back, including a monolithic cat which is higher flow and keeps those pesky smog guys off your cock... Clash: Turbo or not you will still have to get welding done, depending on the size there is quite a difference, but if you just want sound and not alot of performance go with a rear section only. Cheapest by far and if i get a stainless rear, then is it hard to weld regular metal to stainless? also, can i buy something like this? is this what ur talking about? http://cgi.ebay.com/ebaymotors/4-N1-...ayphotohosting |
NO NO NO!! Total rice can!! No an actual muffler not a rice can..this is German not Asian. If all you care about is sound then get a Magnaflow muffler. Cut the old muffler off and weld in the new one.
Swedish, I don't have a turbo, so why would I do a turbo back exhaust??? |
