-   -   I NEED HELP DOING SOME ENGINE TIMING (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/i-need-help-doing-some-engine-timing-7428/)
FRod Feb 12, 2009 03:29 AM
1 Attachment(s)
So i just bought a 94 jetta gl2.0L for $500 bucks because the previous owner replaced the timing belt and it would not run right so he gave up. Well i did not trust his work so i took everything apart and i couldnt believe what i saw. While crankshaft positoned correctly, the camshaft was no where NEAR alighned up with TDC. So now the camshaft and crankshaft are positioned 100% correctly i think?
Alright so this is what i did. I alligned the center of the "O T" letters on the camshaft timing gear with the arrow on the rear guard. With the crankshaft pulley on, i aligned the notch cut in the pulley with the aarow on the plastic lower timing chain cover, and thats how it sits now. I circled in red what seems to have to line up with something what i believe is an oil pump. What do i line this gear up with for correct timing?
Attachment 3713
racerx002 Feb 12, 2009 11:58 AM
RE: I NEED HELP DOING SOME ENGINE TIMING
You just need the crank and the cam at tdc.
