-   -   How to take the top engine cover off. (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/how-take-top-engine-cover-off-6761/)
alwaysdutch Nov 5, 2008 10:45 AM
Maybe a stupid question but I have 2005/2 new Jetta 2.5 and I want to check the air filter, plugs, and other fluids but for some reason I am not able to take the big plastic cover from the engine. I know that there are a few clips at the rear of the cover but they are so tight that I am not able to leave them unlocked. I am afraid I break them accidentally.
Any ideas??
bagel Nov 5, 2008 05:04 PM
RE: How to take the top engine cover off.
certain parts need star shaped bits with a screwdriver
VdubMa Nov 9, 2008 09:38 AM
I dont think there is a real trick to it?....i got mine off pretty easy so i dunno what your doing different...like bagel said try a star bit
alwaysdutch Nov 10, 2008 10:09 AM
Am I looking at the wrong place or so? Are you telling me that those plastic clips in the back have star screws??
If so, that is kind of weird that a consumer will have to use tools just to check some fluid levels
bagel Nov 10, 2008 09:39 PM
wait...what exactly are you trying to do?? You don't have to take any covers off to check fluids.
alwaysdutch Nov 12, 2008 08:14 PM
Well, I am trying to find out how to check the air filter, brake fluid, steering fluid, and probably want to check the plugs. I must say that I have worked a lot on mostly cars from the 90s up to changing out a tranny from my '96 Dodge Caravan.
As I looking now under the hood from my 2.5, a whole new world opens......
As I understand that I should not do too much, I still would like to get used on how to check these things and unfortunately the manual is not that helpful.
Mike
2006 VW Jetta 2.5 - 30,000 mls
1996 Dodge caravan 315,000 mls
scapilot Nov 13, 2008 12:21 PM
My 2009 is the same way... You need to take off the plastic cover over the intake to get at the brake fluid res.
