how to replace plugs and t-stat in 1.8T
Old Nov 9, 2007 | 08:22 AM
RussT's Avatar
Default how to replace plugs and t-stat in 1.8T
The dealer says my 2003 Jetta 1.8T needs new plugs and ignition coils. He wants $385.00 to do it. I see the parts are only about $160 so I thought I would try to do it myself. I have a shop manual and it says I need a special tool to remove the coils and plugs. If I really do then where can I find one? Also he wants $340.00 to replace the thermostat because he sees a "coolant code". I also should be able to do this for almost nothing. Any thoughts on these? I'm I heading for disaster? I have done quite a bit of engine work before but only on American cars. Thanks for any help.
RussT
Old Nov 11, 2007 | 11:32 AM
jetta jack's Avatar
Default RE: how to replace plugs and t-stat in 1.8T
Hi, I just replaced my plugs, wasn't hard at all. Remove the top engine cover, remove some of the bolts that hold dovn your ignitions wires(you don't have to remove all of them) and on the four cylinder remove bracket that holds your engine cover. The square rubber pops off by equal prying ontwo sides.The only reason you have to remove the bolts that hold down the wires is when you pull the plug wire off the plug it is about five inches long. Hope this helps. I never replaced the coils, so I can't help you there. Jack
Old Nov 11, 2007 | 03:41 PM
jetta jack's Avatar
Me again, I just went out and check my jetta and I wasn't completely right. All you have to do is remove the engine cover and the black box that covers the forth plug. Unplug the wires that go into each coil and pry them out. You have four coils that attach too your spark plugs, they are about five to six inches long. No special tools required. Jack
endyraid258
Feb 23, 2013 04:06 AM
chengpnpn
Apr 11, 2012 10:52 PM
punchs
Jan 14, 2009 02:07 PM
emagdnim
Apr 22, 2007 02:41 PM
onecrazyfuq
Aug 27, 2006 01:56 AM
