Head Gasket/Timing Belt Blown Valves?
Ive got a 1992 jetta diesel 1.6 and i just had to replace the head gasket and the timing belt. When i started the job, i rotated the cam crankshaft untill i was able to lock the injection pump and lock the camshaft. I then went about the job and while trying to remove my coolant pump sprocket, my timing belt skipped and the cam moved a little. Iquickly cut off the timing belt and then moved the cam back into position. I replaced the head gasket and timing belt, and i ended up removing the camshaft to clean up around it. i put the cam shaft back the way i believed it came out, with the peg in the end to lock it. and the injection pump never moved because of the peg i had in its sprocket. Today i tried to start it up and it made a horrible loud metallic clacking sound. so i quickly stopped trying to start it.Now im scared ****less that my valves are blown. I tried to move the camshaft with a socket wrench on the camshaft sprocket bolt but i met an abrupt stop. Is my engine toast? what are my chances of having ruined a valve? Is it just being squeaky to get started again? I'm lost and alone and scared and cold someone help me! My legs are tired from biking to work.
Thanks!
Thanks!
bigmike
Jan 25, 2008 05:56 PM
DraconicPhilosophies
Oct 22, 2006 11:10 PM
