Getting Rid of a P0341 Cam Position Sensor Code
anyone have any success in getting rid of a P0341 cam position sensor code. car runs fine, just won't pass a pa emission test with the check engine light on. car is a 98 jetta 2.0L 5 speed
You've picked up on an old thread kehurley80.
As taken from my new https://volkswagenforum.com/forum/ge...oftware-34973/
VAG Error Code: 16725/000833/6039
EOBD II Error Code: P0341
Fault Location:
Camshaft Position (Hall) Sensor (G40) - Implausible Signal
Possible Cause:
Wiring/Connector(s).
Camshaft Position (Hall) Sensor (G40) faulty.
Timing misaligned.
Timing misaligned.
Possible Solutions:
Check/Replace all faulty Wiring/Connector(s)..
Check Camshaft Position (Hall) Sensor (G40).
Check Timing.
Check Timing.
Tech Notes:
Sometimes and in some models, low battery voltage or a weak starter can trigger a Camshaft Position Sensor code.
When is the code detected?:
The camshaft position sensor signal sent to the Engine Control Module (ECM) during the first few seconds of engine cranking is out of range.
Description:
The Camshaft Position (Hall) Sensor is an electronic device used in an engine to record the rate at which the camshaft is spinning. This information is used by the Engine Control Module (ECM) to control ignition and fuel injection. The camshaft position sensor senses the retraction of camshaft (intake) to identify a particular cylinder. The Camshaft Position (Hall) Sensor senses the piston position. The sensor system consists of a rotating part, typically a disc, as well as a static part, the actual sensor. When the engine is running, the high and low parts of the teeth cause the gap with the sensor to change. The changing gap causes the magnetic field near the sensor to change. The change in the magnetic field cause the voltage from the sensor to change. When the crankshaft position sensor (POS) system becomes inoperative, the camshaft position sensor provides various controls of engine parts instead, utilizing timing of cylinder identification signals.
When the Crankshaft Position Sensor system becomes inoperative, the Camshaft Position (Hall) Sensor provides various controls of engine parts instead, utilizing timing of cylinder identification signals.
