Front Struts travel
My local repair shop tried to take me for $1700 in repairs. I took my '98 Jetta in thinking I had a bad wheel bearing or a bad CV Joint. The report from the shop said that I needed both ball joints replaced, both lower control arms replaced, 2 new struts, an alignment, a PCV valve, new plugs and wires, along with 2 new tires. Total in parts - $1200. Labor - $500.
Leary of the report, because my wife took the car in, I decided to wait on the repairs and check it all out myself. Here's what I found: - Ball joints do need replaced (1 is bad, other is good, so replace both), - PCV valve needs replaced, - Tires are less than a year old and in great shape, - Lower control arms are perfect, - Plugs and wires are good (engine runs amazingly smooth), and the real problem: - Both strut assemblies raise up and down about 1/4 inch each when the wheel is jerked up and down. Question - I haven't had a small car with struts for quite some time, but I don't believe that they should raise up and down at all. Do you think they can just be tightened and all is well, or could this be a faulty strut? When on the ground, it acts just like its supposed to, so I'm thinking of just tightening them. Thoughts anyone? Thanks in advance. |
best tv series dvd set store
best tv series dvd set store.!
| All times are GMT -5. The time now is 10:00 AM. |
