Front Struts travel
Old May 19, 2011 | 06:21 PM
Rudy's Avatar
Default Front Struts travel
My local repair shop tried to take me for $1700 in repairs. I took my '98 Jetta in thinking I had a bad wheel bearing or a bad CV Joint. The report from the shop said that I needed both ball joints replaced, both lower control arms replaced, 2 new struts, an alignment, a PCV valve, new plugs and wires, along with 2 new tires. Total in parts - $1200. Labor - $500.
Leary of the report, because my wife took the car in, I decided to wait on the repairs and check it all out myself. Here's what I found:
- Ball joints do need replaced (1 is bad, other is good, so replace both),
- PCV valve needs replaced,
- Tires are less than a year old and in great shape,
- Lower control arms are perfect,
- Plugs and wires are good (engine runs amazingly smooth),
and the real problem:
- Both strut assemblies raise up and down about 1/4 inch each when the wheel is jerked up and down.
Question - I haven't had a small car with struts for quite some time, but I don't believe that they should raise up and down at all. Do you think they can just be tightened and all is well, or could this be a faulty strut? When on the ground, it acts just like its supposed to, so I'm thinking of just tightening them.
Thoughts anyone?
Thanks in advance.
Old May 19, 2011 | 11:12 PM
dvdsetstoreswm's Avatar
Default best tv series dvd set store
best tv series dvd set store.!
bupnl344
Mar 29, 2011 04:10 AM
71_vw_conversion
Nov 12, 2007 02:03 PM
amber505
Jul 17, 2007 09:41 AM
Hoppah
Dec 18, 2006 05:11 PM
Jetta2385
Nov 27, 2006 03:56 PM
