Fault code P0171
Old Aug 23, 2011 | 10:10 AM
lauro's Avatar
Default Fault code P0171
Hi
Ive got a vw bora with the fault code p0171 fuel trim system lean (bank 1)
or system too lean (bank 1) engine runs crap if i pull out the breather pipe to the rocker cover filler cap it runs ok any ideas could it be the maf sensor needs cleaning and i believe you need to use electrical circuit cleaner for this job am i correct????
Old Aug 24, 2011 | 03:47 AM
sales7_euros's Avatar
Member
hello, we can help you solve your problem, we have many VW tools.
Old Sep 7, 2012 | 02:45 PM
Sorry this is an old thread but I've just found it now we've added Bora to the Jetta forum.
VAG Error Code: 16555
EOBD II Error Code: P0171
Fault Location:
Fuel Trim (FT), System too Lean, Bank 1
Possible Cause:
Intake/exhaust leak.
Secondary air injection (AIR) system.
Manifold absolute pressure (MAP) sensor (G71).
Mass air flow (MAF) sensor (G70).
Fuel pressure/pump.
Injector(s).
Evaporation emission (EVAP) canister purge valve (N80).
Heated oxygen sensor (HO2S) (G39).
Possible Solutions:
•In the vast majority of cases, simply cleaning the Mass air flow (MAF) sensor (G70) does the trick. It's best to take it off and spray it with electronics cleaner or brake cleaner. Inspect all vacuum and PCV hoses, replace if necessary. •Check for a dirty fuel filter and proper fuel pressure.
seancycle
Jan 21, 2012 10:05 AM
jeskavw
Jan 25, 2009 09:21 AM
jimmylipps1.8turbo
Apr 27, 2007 02:50 PM
jimmylipps1.8turbo
Apr 19, 2007 07:03 PM
jetta can
Mar 20, 2007 05:10 PM
