eed advice for drivers door window maintenence
Hello and thank you for reading.
Ok here's the deal... Model & Year: 1996 Volkswagen Jetta GLX VR6 THE PROBLEM: I was rolling the window up two days ago when I heard a snapping noise and the window stopped going up (luckily it was almost all the way there). I'd pay to have it fixed if I could afford it, but I'd like to try and get the door panel removed and fix it myself. I've unscrewed all 6 (side and bottom) screws along the sides of the inner door panel. I can pull it out about an inch on most places where it looks like the plastic clips are either broken or detached. How do I proceed in taking the door panel off completely? Key words for this type of problem (to help other newbies find this post in the future): driver door panel removal window fix fell off track how to |
RE: eed advice for drivers door window maintenence
pull the trim off the inner door handle (the part you pull the door shut with) there are 2 screws under there
Ok are there tabs holding the inner door handle in place?
Also, this is for anyone who reads this: I'm looking to buy the rubber side guards for a 96 BLACK jetta... if you know of any for sale (legit sites only plz) let me know! |
Nevermind that was stupid... and incredibly easy..
I took pictures of everything. My problem now is that I need to figure out how to get my window to roll UP... it will roll down just fine, but the damn thing makes a sqeaking noise and then a pop when the wire smacks the glass... |
| All times are GMT -5. The time now is 06:59 AM. |
