-   -   E brake light dim and head lights won't come on (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/e-brake-light-dim-head-lights-wont-come-6364/)
chase2 09-04-2008 10:32 PM
I've tried googleing it and I'm guessing its never happened to any one or I'm wording it wrong. When ever I release the E-Brake, the brake light dims, my day lights don't work, head lights don't work when turned on, and my high beams can only flash. Has any one had this problem or know of a solution? I'm going to need to do some night driving this saterday so any help as soon as posible is greatly appricated! I have a 98 Jetta 2.0L w/manual tranny.
Jrailer 09-04-2008 11:27 PM
RE: E brake light dim and head lights won't come on
might be head lt switch
or bad ground
chase2 09-04-2008 11:30 PM
did some more research on the issue and found out that the wipers only work with the high beams, and the fans come on as well when the high beams are turned on a second time...trying to find something that wont require me take off the air bag
chase2 09-05-2008 12:00 AM
Ok so according to this web site:
http://wiki.answers.com/Q/Why_would_..._do_you_fix_it
its the electronic ignition switch. Does this sound right? I've found it for 9$ so its at least worth the try right?
bagel 09-05-2008 11:13 AM
go for it, what have you got to lose, you get the experience of working on the car, and if you fix it, then you can tell others about it!!
chase2 09-05-2008 12:26 PM
now I just need to find out where it goes. I have a manual for mah car but it doesn't have electronic ignition switch in it, is it called something else?
