DTC Help - 3 Codes that won't reset
Here's my issue - I have a 2013 Jetta Sportwagon TDI - WITH a salvage title so my car has NO warranty.
I have 3 trouble codes that VAG-COM can not clear. I'm not sure what to do here. Any help or suggestions would be much appreciated! Here they are: ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL Component: ESP MK60EC1 H31 0152 Revision: 00H31001 Coding: 114B600C49230001880E06ED921F0042B70000 Shop #: WSC 00066 000 00000 VCID: 7DF1E4F5E40372F6F01-8028 1 Fault Found: 02214 - Tire Pressure Warning 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 73 Mileage: 46044 km Time Indication: 0 Date: 2022.14.01 Time: 19:13:54 Freeze Frame: Count: 0 Count: 14 Count: 20480 Count: 16401 Count: 45568 Count: 10752 Count: 1281 Count: 0 ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 5K0 937 084 J HW: 5K0 937 084 J Component: BCM PQ35 B 021 1068 Revision: BG021001 Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064 802020A040 Shop #: WSC 00066 000 00000 VCID: 397930E5B0AB8ED69C9-806C Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB Component: Wischer 11081 26 0512 Coding: 009795 1 Fault Found: 00955 - Key 1 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 73 Mileage: 46044 km Time Indication: 0 Date: 2022.14.01 Time: 19:13:55 Freeze Frame: Term 15 On Voltage: 12.65 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb Part No SW: 1K0 035 274 D HW: 1K0 035 274 D Component: RNS315-NAR H53 0319 Serial number: VWZAZ2M4265464 Coding: 04000401040007000000100A Shop #: WSC 01383 790 50316 ASAM Dataset: EV_RNS315NARV2UDS 001705 ROD: EV_RNS315NARV2UDS.rod VCID: 2541EC9524131A36C81-8070 Data medium: Subsystem 1 - Part No: 3AA 919 866 B Component: NAR_V3_(0037) 0037 1 Fault Found: 1048669 - Tuner for Satelite Radio B11CF 53 [009] - Deactivated Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 73 Mileage: 46044 km Date: 2022.14.01 Time: 19:13:53 ------------------------------------------------------------------------------- |
VAG Error Code: 02214 Fault Location: Tyre Pressure Warning - Lower Limit Exceeded - Intermittent Possible Cause: Tyre Pressure Monitoring found a low pressure. Even though the tyre pressures where checked and topped up and the SET button pressed this error code still logs in the ecu. Possible Solutions: Just clear the DTC and everything should be ok. It will be logged again in the ecu if the Tyre Pressure Warning Light comes back on. Reset Tyre Pressure Monitoring. VAG Error Code: 00955 Fault Location: Key 1 - Adaptation Limit Surpassed - Intermittent Possible Cause: Key/Remote Control not operational. Key/Remote Control not matched. Key operated more than 200 times while out of range. Possible Solutions: See vehicle specific page for synchronisation/adaptation procedures. VAG Error Code: 00955 Fault Location: Key 1 - Adaptation Limit Exceeded - Intermittent Possible Cause: Key/Remote Control not operational. Key/Remote Control Battery low/faulty. VAG Error Code: 1048669 EOBD II Error Code: B11CF Fault Location: Tuner for Satellite Radio - Deactivated Possible Cause: Digital Satellite Tuner in Demo Mode. Digital Satellite Tuner not enabled. XM/Sirius not activated. Special Notes: This fault code is only a note, it will disappear once the XM/Sirius Subscription is renewed. As taken from my https://volkswagenforum.com/forum/ge...oftware-34973/ |
Thank you for the detailed info.
1) TPMS - It won't reset period. I sit in the car try to reset fault codes and says "OK" and rescan and it's still there. No starting the car or anything. 2) Key - I'll give this a try - Good idea 3) Nav/Sat radio - I was thinking this might be the case but wasn't sure. Thank you for your thoughts on this and pointing me in a direction to try a few things! |
| All times are GMT -5. The time now is 08:34 AM. |
