Trunk won't open (2000 vr6)
Old 01-27-2019, 04:10 PM
duckrogers's Avatar
Member
Default Trunk won't open (2000 vr6)
All it does is click and lights flash.
Would this device help? Anyone use it?
http://jettatrunk.com
I have a video from the inside (removed interior) but unfortunately the format cannot upload here. I can probably email it if necessary (or YouTube?).
Old 01-29-2019, 08:06 AM
Old 01-30-2019, 06:16 AM
You don't post your location in your profile. We do have VAG-COM/VCDS User Locations but very few members add their details.
I've watched that video in your first post, have you checked that?
Old 02-07-2019, 09:37 AM
With VAG-COM\VCDS you can check the voltage and current to components.
Old 05-17-2019, 05:18 PM
duckrogers's Avatar
Member
Default Trunk won't open (2000 vr6) (Not acuator issue)
Trunk issues, blah blah blah.
Bought a new actuator and installed. Worked randomly. Ironically when the trunk is open, but not when closed. After I installed the old actuator, it worked.
See this video:
? He mentions roughly 30 seconds in that the issue was the wire towards the left of the actuator and not the actuator itself. Any idea how I can look into this?
PS: How do delete threads I started? I'd like to tidy up here for others if I can.
Old 05-18-2019, 07:16 AM
Is that your video or one you have found?
Do you have access to VAG-COM\VCDS to check systems out?
If you can't delete this thread confirm that is what you want and I will delete it.
  #7
Old 05-18-2019, 06:35 PM
duckrogers's Avatar
Member
Not my video.
Do not have access to suggested device. But I think I figured it out. See attached photo. When I moved the wire(s) slightly the mechanism worked (and stronger). But I guess I moved it too much and now won't work again. I also noticed my radio reception has got worse. Related?
Referring to another thread. Will comment there. Many thanks.
  #8
Old 05-18-2019, 06:36 PM
duckrogers's Avatar
Member
Please delete this thread. Thanks.
  #9
Old 05-19-2019, 08:07 AM
I've merged your threads on this problem
Why do you want them deleting?
  #10
Old 05-21-2019, 07:37 PM
duckrogers's Avatar
Member
Oh, good idea.
I thought declutterig my posts with no solution would be helpful for other visitors.
Quick Reply: Trunk won't open (2000 vr6)
