-   -   Cooling Problem (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/cooling-problem-4337/)
Volksfan Oct 28, 2007 09:48 PM
Cooling Problem
Hi i really need some advice ive got a 2003 jetta 1.8t, i bought it last year never had a problem with it until about 3 weeks ago my temp light came on so i refilled my prestone and today i noticed that it is back to min. now i checked if i leaked any but there is no spots on the ground, i noticed that while i drive sometimes i smells prestone. could it be i am burning prestone and if yes is that a big problem?????
Thanks in advance
Rennfahr Oct 29, 2007 01:13 PM
RE: Cooling Problem
Check to make sure that your coolant cap is air tight... I know it sounds dumb but that can cause the coolant to evaporate more quickly and cause problems with your car. Make sure you're using the right coolant for our 1.8t engines also. good luck.
emagdnim Oct 29, 2007 11:22 PM
RE: Cooling Problem
did you use the correct kind of coolant? you didn't use green or any "works for all cars"coolant did you?
VW's atleast my 02 GTI takesspecial coolant calledPentosin... I've heard that using the other kinds of coolant will totally gum up your engine.
read your owners manual to check
Volksfan Oct 29, 2007 11:58 PM
RE: Cooling Problem
Well i bought my prestone at the vw dealer so it should be the right one. also i have a rough idel when i stopped at a red light might be the mass air flow sensor????
