Code P0171 cause
Old Mar 15, 2007 | 09:09 PM
jetta can's Avatar
Default Code P0171 cause
Hey all. Replaced my coil,plugs,wires,O2 senser pre cat. and air filter as i was having drivability problems.Drove car to work today and on the way home the engine light came on. Thecode thatthe scanner showed was P0171 - lean fuel bank 1. Any ideas what would cause this.
Thanks
Old Mar 16, 2007 | 08:54 PM
bagel's Avatar
Default RE: Code P0171 cause
Only thing I can think of would be the new O2 sensor disagreeing with the old one, on the downstream O2. Either that or you didn't reset the computer after you installed the sensor.
Old Mar 20, 2007 | 05:10 PM
nweems1's Avatar
try your fuel filter? could case a lean condition.. but there are numerous things that could be wrong.. sure you didnt change the wrong 02sensor .. your other conveter could be clogged..usually and 02 sensor will pull a bank1 sensor # code to tell you the exact one.. just a lean bank could be injectors or many other problems
remission
Sep 13, 2013 05:57 AM
lauro
Sep 7, 2012 02:45 PM
HipHipJorge_20
Nov 7, 2011 12:32 PM
billlikecar
May 27, 2011 02:03 AM
Kyo_clone
Apr 29, 2008 09:45 PM
