-   -   brakes help!! (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/brakes-help-2529/)
copperthumb Feb 18, 2007 10:41 PM
brakes help!!
I am still waiting for anthing on my brake job.
I just now replaced the brake lines too.
Everything is all new,yet the front brakes are still sticking on when the car gets to temperture..
Could it be the newmaster cylinder is faulty??
Or that the master cylinder is not disengaging fully??
I have put in a new booster as well
I am at my wits end!!
HELP!!
VWfan112 Feb 21, 2007 02:53 AM
RE: brakes help!!
Im not sure what year is your car. The newer cars have two master cylinder. One for front brakes and one for rear.
If you only have one then it could be your calipers or you just may have to bleed some fluid out of it.
Let me know how it went
Nick
copperthumb Feb 21, 2007 06:59 PM
RE: brakes help!!
it is a 1991,only 1 master cylinder.
It seemed like the master cylinder was too long and it wasn't releasing..
They seem ok now.
I'll keep my fingers crossed..now on to searching for new tires...;)
Gearjammer Feb 24, 2007 03:28 PM
RE: brakes help!!
Replace your front brake hoses, if you have not already done so. They can become clogged which causes pressure to remain between the hose and the caliper. Also, make sure that you are using the correct fluid.
wicker24 Feb 26, 2007 06:08 PM
RE: brakes help!!
did you make sure to regrease your caliper pistons, also there me be dust in the caliper boots!!
shoughun Mar 30, 2007 07:20 AM
RE: brakes help!!
OnceI had also the same problem like yours... I had done also some brake jobs on my VW, but even getting a new Volkswagen brake booster didn't fixed my problem... When I took it to my local dealer, they just made some alignment and bled my brake system... They told me that the reason why they bleed is to let the air out of the system... Goddluck to you though...
