-   -   Brake noise for the first few minutes (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/brake-noise-first-few-minutes-7184/)
BriGreentea Jan 10, 2009 04:57 PM
Ever since I bought my 07 Jetta the dealer told me they replaced the brakes and may hear some squeaking because water got in there. Well, it still happens. When I turn on my car after it's been sitting for awhile I can hear some high pitch break squeaking in the rear. After the car is driving around for a minute or so it will go away completely.
Anyone have an idea what is causing this? Brake fluid not pumping at the start quickly?
racerx002 Jan 10, 2009 04:59 PM
RE: Brake noise for the first few minutes
Do you park outside? Could just be the rust that forms when your outside.
dbaseballs Jan 12, 2009 01:57 PM
brakes squeak no matter what, there are certain things that make it so you can hear it like if you get a lot of dirt on your rotors it will most likely squeak for you it sounds like once the car warms up it goes away so i dont think its anything to worry about
