Backup lights not working
Has anybody had this problem. I changed the Bulbs but they still won't work. I tested all the other Bulbs(brakes, blinker, running tail lights) but they all work fine. Is their a sensor that could possibly be causing this?
I have never looked for it but I believe there is a reverse switch and my guess would be that it is under the gear shift.
I couldn't locate the Sensor after removing the shifter and boot. I also checked the fuse. This might be a trip to the dealer.
Problem resolved
Their is a sensor located on the side of the manual transmission. The part costs only $25 from the dealership. Very easy fix after you figure out its location.
| All times are GMT -5. The time now is 09:31 AM. |
