Automatic Transmission
Old Aug 23, 2006 | 01:05 AM
dlrtx's Avatar
Default Automatic Transmission
I just bought a 2002 Jetta GL. Can anyone tell me where do I check the transmission oil?
I know that it's front wheel drive but I don't know much about how the transaxle works. I've order an owners manual but have not found anything online that shows how to do so.
Thanks,
DLRTX
Old Aug 23, 2006 | 02:56 AM
bagel's Avatar
Default RE: Automatic Transmission
If I remember right, above the drain plug, should another plug, undo that and you stick your finger in there and see what color it is, and how much you have. I've done it that way on other trans, but not sure if it was auto, may have been a manual, sorry can't remember. Most of the time, I've seen dipstix that are really short, so it's not confused with the oil dipstick. Look for a dipstick that goes down into the trans, otherwise I'm not really sure.
Old Aug 23, 2006 | 10:55 AM
Joelzy's Avatar
Ive seen some with dipsticks and some (like bagel said) that you have to pull out the plug and stick your finger in to feel the level. not sure on these cars though.
Old Aug 24, 2006 | 07:51 PM
emagdnim's Avatar
yeah, it should have a dip stick, usually its manuals that you need remove a plug and check for gear lube.
check your owners manual or check around online for shop manuals or something
Old Aug 30, 2006 | 05:26 PM
gbest's Avatar
As you are facing the car, look down at the transmission just behind the starter, you can barely see the fill tube. If you get under the car and remove the four screws holding the plastic cover under the tranny you can see the entire tube. It will have a red cap and once removed there is a plug that may be removed to add fluid. The tranny is a "sealed unit that should not require any additional fluid. Checking the fluid level is achieved by starting the car and putting in gear (not sure which gear off the top of my head). remove the drain plug and fill untill fluid runs out...replace plug.
There is no dipstick
Old Aug 30, 2006 | 05:38 PM
gbest's Avatar
If your car is an automatic!
Old Aug 31, 2006 | 06:37 AM
  #7
bagel's Avatar
There you have it! Thanx for the info, hopefully this becomes useful to our auto trans members out there.
Old Oct 31, 2008 | 10:58 PM
  #8
cris?jetta's Avatar
Default RE: Automatic Transmission 01M
I would like to know if a vw mk3 manual transmission, would fitmy jetta mk4, since my auto transgot broken and is very hard to find out the replacementpart.Soiamseriously thinking inmake it manual.
Old Nov 3, 2008 | 07:35 PM
  #9
clash0901's Avatar
Member
ORIGINAL: cris?jetta
I would like to know if a vw mk3 manual transmission, would fit my jetta mk4, since my auto trans got broken and is very hard to find out the replacement part. So i am seriously thinking in make it manual.
lol. easier, cheaper, and quicker to buy a whole new mk3, or even mk4 if you find a good deal...
updog23
Apr 14, 2012 03:43 PM
libertyh
Apr 27, 2007 02:47 AM
damas
Oct 3, 2006 12:28 AM
gbest
Aug 31, 2006 06:35 AM
oleg_8831
May 25, 2006 07:10 PM
