-   -   automatic tranmission problem (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/automatic-tranmission-problem-811/)
rusky May 20, 2006 03:30 PM
i got a 99 jetta gls form the aution, has a 2.0 engine. when i first took it out for a spin the gears shifted hard and it jerked when i put in drive or reverse. so i knew it had to to be the fluid. so i drained it. it was black. so i fulled it up with. but still has the same problem. then i filled it up with some more because it was low. it drives better but the fluid is dark red. and suggestings
bagel May 20, 2006 05:24 PM
RE: automatic tranmission problem
what kind of transmission fluid did you use? You might have to flush your tranny for a bit, whoever had the car prolly didn't take care of it.
p_mister May 20, 2006 08:47 PM
pull the whole tranny pan and clean it out really good. and then go from there.
tony
