99 VW Jetta GLS 2.0 Cold Start is Very rough, but smooth after warm, strong fuel smel
Hi, I am having a hard time resolving this issue.... My 99 Jetta GLS 2.0 started having this problem after I let some @$#hole replace my plugs/wires. When you start the car after it has been sitting (cold), it has a very hard time starting and idling for about 30 sec. with revving the motor, almost as if it was running on 3 cylinders. It also has a strong fuel smell and keeps generating misfire codes P1300, PO300, PO301, & PO303. I have re changed the plugs, wires & the coil pack myself, and it still has the same problem. I have to smog this car but can't very well do that with what's going on for it WILL fail. Anybody have this problem ? My thoughts lead me to a faulty ECM..... HELP?
Don't think that making an intro will fix this comment as you've already ask the question. Google these error codes. EOBD II Fault Codes Software Please tell us your car spec in your signature |
