-   -   99 mkiv jetta - Transmission Problem? (https://volkswagenforum.com/forum/volkswagen-jetta-bora-19/99-mkiv-jetta-transmission-problem-5436/)
stonersmurf Apr 12, 2008 10:36 AM
Sometimes when I switch the car from park it takes a second or two to switch to drive or reverse or neutral. Also, sometimes when the car downshifts after I let off the gas, it seems to have a slight jerk.
I'm hoping I just need some new auto-tranny fluid. Ideas?
bagel Apr 12, 2008 12:40 PM
RE: 99 mkiv jetta - Transmission Problem?
Auto?? There may be a sensor going bad that tells the tranny when to shift, that could explain the jerk.
Jrailer Apr 12, 2008 07:01 PM
low fluid will do this
michjettaTDI May 21, 2008 08:29 PM
I have an 02 Jetta that is starting to do the same thing. What did you ever come up with as a solution?
woody1 May 22, 2008 09:40 AM
my 01 is doing the same thing, but the more i the more i keep off the gas the less it dose it. i did talk to a dealer about that subject, but without takeing it in he said that he was 85%sure that thare was nothing wrong.so natralyiassumedit was normal, being as thoue when i got it it was alredy doing it .i gess that it makes sense thoue that thare would be somthing wrong.
now i have heard rummers about that trans being bad but havent realy ben abil to find any cases or met any one who can conferm it
i would also like to know what you came up with.
