99 mkiv jetta - Transmission Problem?
Old Apr 12, 2008 | 10:36 AM
stonersmurf's Avatar
Default 99 mkiv jetta - Transmission Problem?
Sometimes when I switch the car from park it takes a second or two to switch to drive or reverse or neutral. Also, sometimes when the car downshifts after I let off the gas, it seems to have a slight jerk.
I'm hoping I just need some new auto-tranny fluid. Ideas?
Old Apr 12, 2008 | 12:40 PM
bagel's Avatar
Default RE: 99 mkiv jetta - Transmission Problem?
Auto?? There may be a sensor going bad that tells the tranny when to shift, that could explain the jerk.
Old Apr 12, 2008 | 07:01 PM
Jrailer's Avatar
low fluid will do this
Old May 21, 2008 | 08:29 PM
michjettaTDI's Avatar
I have an 02 Jetta that is starting to do the same thing. What did you ever come up with as a solution?
Thanks
Old May 22, 2008 | 09:40 AM
woody1's Avatar
Member
my 01 is doing the same thing, but the more i the more i keep off the gas the less it dose it. i did talk to a dealer about that subject, but without takeing it in he said that he was 85%sure that thare was nothing wrong.so natralyiassumedit was normal, being as thoue when i got it it was alredy doing it .i gess that it makes sense thoue that thare would be somthing wrong.
now i have heard rummers about that trans being bad but havent realy ben abil to find any cases or met any one who can conferm it
i would also like to know what you came up with.
s15jfedele
Jul 8, 2013 08:13 PM
clabz
May 16, 2010 01:18 PM
turbo8283
Mar 19, 2008 10:08 PM
MKIVJETTA2POINT0
Feb 4, 2008 10:28 PM
WoDan23
Apr 2, 2007 01:47 AM
